Hi,
Could anyone please post up a pic of the standard vac lines around th EGR valve? Also including the two little electrical things that are plugged in but have vac lines (they look like little valves or temp sensors?). Edit: I think these are VSVs?
I have replaced manifold gaskets and think I may have plugged the vac hoses back incorrectly as it now shakes on shut down....bit like when EGR is blanked.
I also had the wires on one of the VSVs snap and had to repair - there is a chance I failed here and therefore, if the VSV was essentially not plugged in, would this also lead to the same symptoms?
Should have taken photos before I started but didn't!!!
Many thanks
Alex
Many thanks
Alex
