Hello
I need quick help, I wanted to change the gasket from the drive shaft at the back. (Since I have oil in the brake drum). If the wheel has been removed, the brake is dismantled so far (train removed, etc.) now the brake pipe which is at the rear brake shoe backing plate is still disturbing. I do not get this down, because the 10 ner foot wrench is no longer properly grasped (once one has broken the screw). How do I get the shaft removed to change the gasket, or does anyone have a trick to remove the screw (pipe). Because my Hilux jacked up on the street.
Thank you
Thank you
