Replacement timing belt
  • Replacement timing belt
    Can anyone recommend anyone that can replace a timing belt and reset the clock on my 3rd gen Surf in the Merseyside area. Cheers Jim
    Hi Jim , I am led to believe they are relatively easy to do on the 3rd gen model , when I got my 3rd gen it was done in about 20 minutes , not sure who is in your area , if you can get to Basingstoke then tony is your man , but I am sure any decent garage should be able to to your timing belt , not sure if this helps or not , good luck
      Belt
      Thanks for replying, I'd love the famous Tony to work his magic,but he's a couple of hundred miles away. Cheers. Jim P.s. Happy new year everyone
