Can anyone recommend anyone that can replace a timing belt and reset the clock on my 3rd gen Surf in the Merseyside area. Cheers Jim
Replacement timing belt
Hi Jim , I am led to believe they are relatively easy to do on the 3rd gen model , when I got my 3rd gen it was done in about 20 minutes , not sure who is in your area , if you can get to Basingstoke then tony is your man , but I am sure any decent garage should be able to to your timing belt , not sure if this helps or not , good luck
