When the timing belt needs replacing the light comes on and is reset i believe via a button on the dash through the plastic fascia, but what do you do when you've replaced the belt (put a new cylinder head on so put new belts on aswell.) when the light hasn't come on, can you still push the button and will it reset for the correct mileage.
Also with a new head/head gasket, do you need to torque it down again after so many miles, i've only ever worked on bike engines before and this has always been the norm with a new head gasket.
