Wonder if anyone can help
So 3 weeks ago the surf was ticking over fine.
then stopped.
I was low on fuel but not empty and there was no warning light.
So first thing I thought it could be was fuel, took the hose of the filter and started pumping the primer, found out the primer no longer works.
New primer and filter, tried again
Still not starting, read the forums and discovered that there are little filters in the pump, I removed the pump and cleaned the filters.
While doing this the batteries were disconnected which wipes the ECU
Put it all back together and it started, but with a ECU warning light....hmm
Drove it round the block, ECU goes away and comes back, then engine dies![Frown](https://hiluxsurf.co.uk/core/images/smilies/frown.png)
Call the AA, DIAG check - Crank sensor![Frown](https://hiluxsurf.co.uk/core/images/smilies/frown.png)
I fitted a new crank sensor (Genuine Toyota part) .
Tried to restart![Frown](https://hiluxsurf.co.uk/core/images/smilies/frown.png)
New error - Error 22 - Water temp sensor - yep while fumbling around I broke the plastic housing.
New water sensor (Genuine Toyota part) later
Try again....
still no start
Now when I read the ECU code all im getting is constant flashing![Frown](https://hiluxsurf.co.uk/core/images/smilies/frown.png)
Any ideas ?
Up till now the Surf has been brilliant.
then stopped.
Tried to restart
Try again....
Any ideas ?
