1995 Hilux Surf Diesel
Model KD-KZN130W-GKPQT
Frame KZN1320-9074028
Over a month ago, I was coming out of a business parking lot. As I accelerated out from the lot, my engine lost power abruptly and shut off. I then preceded to restart the vehicle and continued on my way. I did not think much of the issue because the vehicle ran fine for a while after that incident, however a very faint sputter at idle could be notice if you where attuned to the vehicles performance
Four or more weeks after the incident, I was driving along leaving work when the engine died on me again. this time I was unable to restart the vehicle. The next morning while I was waiting on the tow truck driver, I decided to try start the vehicle. the vehicle started and ran for a while. I drove the jeep for about 5 minutes, then it started to lose power again slowly died. after that the vehicle would not start anymore.
Troubleshooting
tested crank position sensor
changed fuel filter
took the injector line off to see if any fuel flow to the injectors while I cranking the engine. No fuel flow to the injectors. Fuel seen leading to the injector pump
Conclusion
I found the fact that the engine started after sitting over night suspicious.
I am hoping that it is not the very expensive Fuel injector pump.
If there is anything else I can check or look at, please let me know.
Troubleshooting
changed fuel filter
Conclusion
