Hi,
I was planning to replace the brake discs on my KZN185G (the narrow body version), but I've noticed that the G version uses 297x22mm discs while the W (wide body) version uses 319x22mm discs.
I'm assuming that the KZN185G was originally fitted with 15" wheels, hence the smaller discs.
From what I can see, the larger discs are much more widely available. My truck's already got 16" wheels on, so I was wondering if anyone has fitted the larger discs/calipers (and dust shield) from the wide body onto the narrow body.
The steering knuckle is the same part number on both models, so I don't think there'll be an issue, but it's always good to know if it's been done before!
Thanks,
Dan
Thanks,
Dan
