I'm fitting an immobiliser to my newly purchased '96 KZN185 and one of the circuits I was going to break was the feed to the spill control valve relay.
I've seen a few references to the relay being behind the glovebox, but I haven't spotted anything around there.
I've checked several different wiring diagrams that I've found online, but although the basic circuit remains the same, the wire colours are all different. I'd rather check the relay itself to confirm the wire colour before assuming the ECU pin number is correct
Anyone know where it's hiding?
Thanks,
Dan
Thanks,
Dan
