Hi Everyone,
I've owned My 1994 KZN130 Surf for just over 3 years now, & When I've had problems I've found all the information needed on this brilliant Forum. However, now I've got some problems & cannot find the answers! Could anyone Advise please?
Had this problem for around 2 months. when I turn the key to start, the starter engages but just jams & doesn't turn the engine over. I read that a common fault was the contacts wearing out, but that symptom was clicking rather than the jamming that I had. But I thought I'd fit a new kit anyway as that might cure it. It didn't. (Worth a try though) The engine was only jamming about once every so often anyway, maybe once or twice a week. It got to the point where I broke down miles from Home. Rang RAC, He banged on the starter motor with a metal bar. It started! He said it needs a new starter motor. So I fitted a new one. I still have the problem! It took a turn for the worse last week, as I went to start it up & it jammed, followed by a really loud clattering noise!! I tried to turn the engine by hand with a socket & breaker bar on the front pulley. It wouldn't turn! I thought the engine was seized! I rang the RAC. Meanwhile I tried to turn the engine the opposite way. It turned! I turned it the right way again & it turned! I tried to start engine again &...It started! (I cancelled RAC Call out). It's been nearly a week since then & everything has been fine! BTW, once the engine is running everything is fine like normal. The auto gearbox seems ok too.
Has Anyone else had this problem? Does Anyone have any ideas of what it could be? Any help or advice would be greatly appreciated!
Many Thanks..Simon
Many Thanks..Simon
