Hi,
This is the 2nd time I have replaced the cambelt and using the instructions on this site, the job has been straight forward and I did not have any problems last time. i thought it would be the same today!
But when I came to replace the Tensioner a bolt sheared off level with the back casing, so there is nothing to get hold off to remove it.
Im trying to find out if the bolt can be extracted without having to strip the whole car down, as there is not much room especially as it is the lower bolt that has sheared!! And if anyone can give me advice on how to do it without ruining the thread in the cambelt casing or causing any problems behind the casing.
Thanks for reading
Cara
Thanks for reading
Cara
