hi everyone,
so when air con is switched on I get a squealing noise that comes and goes. more often than not it squeals. is that the pump or could it be a bearing? I'm not too bothered, if it's an expensive repair, because I don't use the air con very often anyway but if it's a fairly easy fix I'll do it.
anyone else had this issue??
I can't complain really, this is the first issue I've had on this surf that wasn't of my own doing!!!
thanks in advance
thanks in advance
