Ok sorted it now and thanks
3L Automatic and Towing
Just done a lot of reading on line and some say as long as in neutral you can tow away forever and a day and some say it will mess up your transmission, so which one are we to believe ? as I always thought that towing was a no no with an automatic.
I have read that automatics with flood lubrication(splash lubrication) can be towed. The lubrication of the gearbox starts if the wheels are turning, no need for the engine to run.
Automatics which need a pump to lubricate the gearbox can not be towed whithout damage. The pump is driven bij het engine.
Planetary transmissions, CVT, Honda automatics, dual clutch transmissions and VW/Audi automatics are better of not having a tow.
Questions remains what kind of transmission is in the Sufr/4runner?
done that several times with several surfs, and i think thats the best and safe way to tow, putting the 2 levers on N as wellOriginally posted by Tallyman View Postdisconnect the prop shaft, then you can tow for ever without damaging the gearbox.the wolf is always bigger when you are scared!!
