hi my 1991 3 ltr diesel surf runs well smooth uses no oil but now and then intermittently I get a clanging noise a bit like a bearing breaking up coming from front of engine it only does it when driving along road, never when stationary temp is normal no water leaks so I wonder if water pump is going or maybe a belt tensioner starter motor sticking etc. so my question is anyone else ever had these symtems and what was the cause.
Engine noise when moving
Up or down hill or on flat but I noticed fan belt slack so I adjusted it now hardly any noise but when it does it's not so loud more a altenator bearing noise, I'm going to ride it out see what develops it's charging normal not overheating no water leaks, it's had a engine change at some point in its life it's registered at dvla as a 3ltr got 3 ltr ln130 on makers plate and 1991 I think it's a special.
Thanks for that jameswallace, you have confirmed what I thought , I adjusted this belt and so far no noise it was very slack before I may get a new belt as the adjuster is at end of adjustment.Originally posted by Jameswallace View PostI used to get a terrible screach from the engine occasionally. Turned out to be the A/C belt slightly loose!
