Evening
It seems to be a right pain in the arse to start my truck
Symptoms are
Dead cold = almost impossible, but will start. Cut out and then start again
Warm ish - takes a bit to start
Up to temp takes a bit longer than usual
If i switch it off then re start again straight away it is fine, but if i leave it just 10'minutes it doesnt start straight away as before
This problem has occoured since playing with the fuel pump timing, but surely the fuel pump timing wouldnt cause poor starting? I have returned the pump to its original position but no better
I have fitted my new tcv but no better
I have put a peice of clear line in the fuel line to see for air, seems a tiny bit but not enough, once running it isnt down on power it pulls like a train! I fitted an outboard primer bulb, all this did when pumpted eas create pressure in the pump (i found out when i undid the tcv bolts)
so would it likely be glow plugs? They are only a year old and NGK's...
Im reluctant to go to all the effort of getting too the damn things if someone has a better idea what it could be
Many thanks in advance
Symptoms are
