I did search but didn't really get an answer
Is it as simple as loosen the two 13mm nuts and loosen the bolt in the back and adjust until it makes a detonation sound then move back a bit?
When we put the new pump in we timed it but when it was cold.
If some one could clarify the correct procedure that would be great. Thanks!
The reason i want to adjust the timing is when i had the red light tcv fault the tcv was sticking keeping the pump advanced. Which made it idle beautifully. Whereas with my old tcv valve it idles rough so want to eliminate bad timing before changing the tcv for a new one at nearly £200! Im assuming my tcv is working so the pump isn't advanced enough i guess
