Quick question really my 3.0 surf seems to be idle at around 500rpm and is shaking the whole car. I have had this happen to me before but then it just stopped. I know the engine is running from ecu. Any ideas would be great thanks
idle speed
It's due to change filter possibly getting it done tomorrow would that change the idle speed. I know the idle speed is done through ecu. The rpm is around 500 which is low. As I put it into drive and have foot on brake the vibration just seen to be getting worse
Dodgy spill control valve. Check the resistance with a meter.it should read 1.4 ohms open circuit ( plug disconnected). The spill control valve is the same on the 2lte and the 1kzte pumps.Last edited by surfenstein; 30 December 2014, 00:31.www.overfab.uk
As far as I can remember, they were about 40 quid each plus vat, they're sold on an exchange basis, you get the new ones and send the old ones back to be refurbished.
Prices may have changed since then and my Surf is a 2.4, not sure if this makes a difference to the price or not.
Just google Diesel Bob to check availability
