Hi, I feel bad as I only visit when I have a problem...
Anyway, I am in Morocco so don't have anyone who knows anything to ask.
So, here goes...
1996 KZN185 230k Kms, No mods.
Sunday changed oil.
Monday School Run – Started ok, drove about 1km, and cut out, as if ignition turned off, no chugging. Restarted and ran another 200m and died again. Restarted once died after 2 mins idling.
I checked the forum and have done the following.
Recharged the battery. Checked for obvious disconnects around the area of the fuel pump. Nothing found.
Replaced battery and restarted engine which ran for five minutes with no problem until I turned it off.
Fault codes. Followed the E1 – TE1 connection and on ignition switch have rapid alternate flashing of engine and O/D light four times then nothing. Visual inspection around fuel pump indicates fuel seepage around the base of the Engine Speed Sensor.
So the questions are
Do the fault codes indicate no logged fault? Or, could log fault have been cleared by removing the battery?
Would a leaky engine speed sensor, trigger some cut off somewhere?
Is it as ‘simple’ as replacing the O rings on the engine speed sensor?
Can the lid be taken off with the fuel pump in situ?
Any help would be greatly appreciated.
Cheers, Steve.
So, here goes...
Sunday changed oil.
Cheers, Steve.
