Today the surf went to the garage to have a new head fitted, old head off, one big crack between No 3 cylinder and waterway few smaller cracks starting between the other cylinders but No 3 was the killer no liquid steel was going to fix that one! Am having the timing belt ,water pump, thermostat,rad cap and radiator replaced at the same time, the water ways look clean with no residue from the liquid steel (which kept it working for 4 months).
Will be getting it back early next week then the soarer goes in to have a new rear sub frame fitted,it has a broken stay rod bracket rusted through and nearly broken off allowing the rear wheel to move sideways at the front edge.
new head, gaskets,glowplugs, bolts, waterpump, timing belt, thermostat, radiator and cap ,new engine oil and filter and new coolant fluid.
