My Surf had a service 3 weeks ago, soon after I noticed when pulling away from stop, there was a slight delay before I got traction, sometimes accompanied by a lurch.
I ignored it for a few days, then dipped the transmission oil and the stick was dry.
I went straight back to the garage (last Friday) and they put about 3 litres of transmission oil in before it showed the correct level.
(I understand the capacity is about 6litres, but half remains in the gears)
The assumption was made that I had suffered a "catastrophic" loss of transmission oil and must have quite a leak.
The vehicle was booked in for Monday (tomorrow) for investigations.
I have run the vehicle over short distances in the last two days and there is no movement in the oil level on the dipstick and no evidence of oil leaking on the ground where I park.
During the service the garage say they check the transmission oil and that is all.
Any ideas how I "lost" so much oil, if its not a "catastrophic" leak.
Does transmission oil usually need topping up regularly ?
