Hi all, just done the viscous (should be vicious?) fan again. Still overheating, so elected to use 10,000 cst silicone oil (5,000 last time) Bought over t'internet from RC shop, sold as 10000cst silicone oil for diffs/shocks. Job done and took her for a test drive. Overheating within 5 miles, on the flat doing about 60mph. Took her gently home and had to nurse her up a gentle slope as temp was seriously redlining! Pulled over and gave the fan a spin by hand....absolutely no resistance whatsoever. I've never even seen one spin so freely before. Duff oil do we think? Put the correct amount in ~ 50mls. Gasket in place properly, all screws good and tight, no leaking apparent. Turned by hand when cold and slight resistance as to be expected before driving off...big smile for a couple of miles...big disappointment again.
Am awaiting new thermostat and rad cap from Roughtrax to fit later this week and thought I'd get the fan done in readiness so all cooling issues would be sorted. However, if fan shot then all to no avail. Having spent many, many hours trying to sort out these problems over last couple of years, am beginning to think that a Kenlowe fan should/could be the answer? Anyone fitted/used/heard of any problems or good things to say about them?
Perhaps I've got the oil weight wrong? Anyone got a reasonably definitive answer for what I should use>
Thanks in anticipation
