Hi guys I need your expert opinions.
I was rally marshaling last weekend and my truck developed a squealing noise.
I got it up in the air this weekend hoping to fine a stone lodged somewhere!!!
No joy.
The noise only happens for a few seconds when accelerating then goes if on a run will not make any noise until you pull up the pull away again.
it sounds like it is coming from the transfer or auto box.
I replaced the transfer box oil and replaced the yearly transmission fluid refresh still no joy still makes the noise which i can only describe as a metal on metal scraping noise which is quite high pitched and sounds like a stone lodged in a guard rubbing against a prop.
I have looked down the forum lists and i have not found this issue anywhere. am I looking at a transfer box component or is it something more serious.
Many thanks in advance.
No joy.
