Does any one know what size the thermostat o ring is on a 3l TD or do i just buy another thermostat to get an o ring.
o ring size
Andy
Have a rubber here to fit your ring
http://www.roughtrax4x4.com/?doc=16&cid=164&vid=547
Buy the Sealing ring from any Toyota dealer
LOL, I should have expected that!Originally posted by woodwarm View PostAndy
Is it not just a normal o ring, i'm going to be taking the thermostat cover off to do a coolant flush and just want a replacement gasket for when i put it back on, as far as i know the thermostat doesn't need changing. If it's not a standard o ring then it looks like i'll have to buy a thermostat which is an expensive way to get a gasket.
