after taking the surf for a swim before xmas it seems to be a little unwell.
it starts and runs with normal oil pressure when cold, but once upto temperature there is some blue smoke from the exhaust and the oil pressure drops to nothing.
if it is stopped when warm and you try to start it again the starter motor does not seem to have the power to turn the engine over, but after being left for half an hour will once again turn the engine and start it.
the oil has not turned milky and is still at the usual level, and does not feel overly thin.
i have put a block tester on the cooling system and it did not detect any exhaust gases in the coolant, and the coolant level is still normal and looks clean.
i have dropped the fuel out and emptied the fuel filter and it does not seem to have got any water in the fuel system. something strange but probably unrelated, when i removed the fuel filter, fuel seemed to gurgle out of the filter housing and the filter was only half full.
any advice on what i should check next or possible causes of my problems would be greatly appreciated or feel free just to take the pi55
cheers joe
cheers joe
