Hi Vince
I am having fuel starvation issues again.
This time, it's not the fuel filter (it's new) and fuel seems to be flowing freely from the tank, through the heat exchanger and through the filter, when I squeeze the primer bulb.
However, the fuel line from the filter then goes into the IP and that's where my investigative powers stop!
I removed the sensor that normally houses a small cylindrical filter in the IP and I am not convinced the filter is in there. At least, I can't get it out, if it is in there. There was a slight build up of sludge on the sensor.
Is it possible to come up at some point for you to have a look? Or would you like me to try something here first?
Cheers!
Cheers!
