Not wanting another cracked head, I tend to keep one eye on the temperature gauge when driving. The needle usually sits just under half way across the scale but if there's a long hill (even a shallow one) the needle fairly quickly goes up to just under the red section - and just a quickly goes back again when the road levels out. Cracked head/gasket or maybe just a failing thermostat?
Another concern: occasionally when starting from cold, it will sound as if it's firing on three cylinders and emit quite a lot of blue smoke from the exhaust - after a minute or two, the engine returns to a smooth idle and the smoke stops, after which it's usually fine for the rest of the day. This usually happens after it's been: left for a day or two; on a long run; very cold/damp outside.
Sticking injector or something worse? - and are the two things related? Grateful for all suggestions.
