Hey guys, I'm having trouble getting my fuel system bled after reinstalling the pump and injectors. I have the glow plugs out and the injector lines cracked loose, and pressure at the lift pump. I filled the pump itself with diesel prior to starting (through the return bolt on top) BUT after spinning it for about 10-12 seconds, waiting a few minutes, then spinning again, I'm still not seeing fuel puddling, leaking, or spurting at the injectors... Is there a step I'm forgetting? Does it just take a lot of spinning? It was running before, and the spill valve and timing control valve are withing spec per the FSM.. timing belt was set spot on, and I aligned the punch mark with the machined surface on the side...
Any help would be greatly appreciated!
