Ok I have about 6 litres of Halfords red "organic acid technology" long life coolant. (Got it very cheap)
I've read loads on the internet about what to use & what not to use but I am getting confused the more I read!
So as far as I see if I drain the system and flush it clear it should be ok to use the halfords stuff?
It'll probably only be in for a while as I think the head needs doing at some point anyway. It uses a bit of coolant
I'll top up with distilled water.
The reason for doing this is I don't want to spend £40+ on toyota coolant and have to get more to top up with, if I use the halfords stuff I can get that easily.
Does this sound sensible?
Thanks for any replies....
