Hi all just a quick question!!
When not in 4wd the front inner end drive shafts are loose, then when engaged they are solid which I would have thought is normal?
I think mine has a problem when not in 4wd because the drivers side is very loose.If i jack the car up and pull the wheel I get a clonk and movement (only once) and it will only move again once after driving it.The 4wd is working fine.
Is there anything I can adjust as the mot is soon?
