I recently did an oil change and checked the belts. They were fairly slack as I hadn't looked at them since I put them on about 18 months ago. I adjusted the tension via the alternator. Now I have this strange 'squealing' noise when i rev the engine. I can hear it more in the cab than in the engine bay and I struggle to get the noise going when I use the throttle cable to rev it.
It is more a bearing type noise than a belt noise. Temp stays ok, oil pressure is good and it pulls like a train, I'm a bit mystified but using it for commuting with loads of gear in the back currently and really don't want to break down on th' motorway.
Any ideas appreciated.
