Hey guys,
1995 KZN130 Hilux Surf 3.0L TD auto.
Have had an issue pop up that is rather annoying. The truck will drive fine in 2WD, it will also go into 4WD (low and high) fine. The issue arises when I try and get the truck OUT of 4WD and back to 2WD. Whenever I try and get out of 4WD the light stays on and trucks seems to stay in 4WD no matter how many times I try - yes I've done the reverse trick and back & forth trick a million times - it just won't come out.
However, I've found that turning the key to the OFF position and then back to ON (whilst the truck stays running due to the turbo timer) the 4WD light will go out and the truck appears to be back in 2WD, if it doesn't work the first time it always works the second.
I have crawled under the truck and the front drive shaft does NOT spin freely (when in 2WD) as it should. I've jacked up one front wheel at a time and they spin freely and do not cause the front drive shaft to spin so the front diff is NOT engaged and the ADD appears to be working correctly. I've jacked up both front wheels at the same time and both spin freely and don't spin the other and also don't spin the drive shaft. I have crawled under the truck and had someone press the 4WD button ON/OFF and I can hear the motor on the transfer case going (although not very loudly). I've replaced the 4WD ECU under the head unit with a mates ones out of an identical truck and the issue remains.
I've posted up on numerous other forums and no one seems to know what's going on. Has anyone on here seen or heard of this front drive shaft/4WD sticking issue before?
I'm not sure if it's something mechanical, electrical or vacuum-related causing the front drive shaft to stay engaged all the time and make the truck stick in 4WD (unless the key is moved to OFF then ON) or if these two issues (drive shaft and sticking in 4WD) are even related!
Someone please help!
Thanks
EDIT: Is the transfer case shifter motor the black circular bit on the top of the transfer case that is attached with what looks like two screws?
Thanks
