I replaced my injectors and then developed a mystery fuel leak
I replaced the leak off washers and leak off pipes and i am still getting fuel on cardboard underneath
It seems to be running down the engine and dropping off the exhaust and the front diff...
Its not a huge amount but enough to show..
Im running 100% veg, so could it be the O ring on the pump on the top? Definatly leaking something
Is it a conventional O ring? Or is it a toyota special oval ribbed with a big price?
Any clues on size if its 'normal'
Its hard to pinpoint it with hurricane toyota blowing everything in its path...
But assuming i can easily change the O ring is it "simply" a case of undoing the humungoes nut and take it out with a replacement o ring on rebuild?
Thanks
Thanks
