Please can anyone help I have just changed my 3ltr engine with a cracked head for a newer better 3ltr. New engine runs like a dream but when I put it into gear there is no drive what so ever in any gear 2 or 4 wheel drive. The tork converter didn't come off the gearbox at all. Oil levels are fine and while the engine is running and in gear I can lie underneath my beast and I can see the fly wheel and the tork converter turning fine it is just not coming out the other end of the gearbox. I'm really stuck and any suggestion would be great as I am lost totally. I have talked to a very nice man a ecu doctor who is going to look into it as well and he said to put a shout for help out to you guys. Many thanks Craig. Forgot to mention there is no oil flow as I have taken pipes off bottom of rad and there was nothing what so ever .
Auto box no drive please help
Sounds like the torque converter isn't seated correctly on the transmission input shaft and the pump isn't turning.
There are two sets of splines on the shaft and when fitting the T/C, it can feel like it's seated but it's actually only meshed with one set of splines.
Place a straight edge across the bellhousing and measure the gap. There should be 17mm clearance from the mating face of the bellhousing to the threaded holes of the torque converter.
