Hi.
Is this an acceptable way to change the rear springs on a gen 3.
1. Remove bottom shock mounting bolts and split from axle.
2. Using a jack and support, lift one side at rear on chassis, allowing axle to maintain position with wheel on the floor.
3. check that brake hose doesn't become stretched at tee piece.
4. remove old spring and replace with new.
5. Lower vehicle and repeat on opposite side.
6. Refit bottom shock mounts.
Or will i need some spring compressors.
Cheers.
Cheers.
