Since lifting my truck the steering is rubbish. i took it to the garage to get underneath it and what a complex steering arangement it has. so everything is tight underneath and in good working order. however, due to the fact there are so many ball joints on the whole mechanism i can move the front left wheel in about 2-5 degrees without the drivers sid wheel moving at all.
this is starting to really get to me as its really noticeable when doing quite precise driving off road. even on road constantly correcting and wandering. has any of you encountered this problem? also has anyone actually looked into modifying the steering and maybe trying to lose the pitman arm and idler arm ball joint for some other replacement which would stop the main steering bar moving up and down, so would at least cut out some slack.
any help would be great.
