In an effort to solve my fuelling problems, I have been checking parts of the fuel path.
When I put the filter back on and try to prime the system, I get no fuel coming into the filter. Does the system have to be sealed to do this or can I leave the exit line off so I can see the fuel being squirted out when it's full? I have pressed the primer a few hundred times now with no success.
) and try starting the engine. If it starts, you may not need the primer until next time.
Ensure the small 'O' ring in the water drain tap is serviceable, as a small air leak here can cause difficulties too.
