Earlier this year I had an issue with my IP, resulting in me getting a second hand one fitted. It has worked very well up until now.
If I am driving at approx 30 mph and floor the throttle, the engine goes flat for a few seconds, I lift the throttle and press it a little slower and the engine then accelerates as expected. This problem does not happen all the time.
I had a similar experience with the old pump but that came with the engine light and the dreaded error 14.
I run veg oil and 10% petrol and I believe it to be clean and well filtered. I have a heated filter and flat plate heat exchanger but it still has the problem at normal running temperatures. There is no smoke.
I have not tried the usual yet... filters, blocked pick up, run a tank of diesel through, but wondered if it could be something else perhaps? Maybe turbo? There is no unusual sound that I have noticed.
yea the whole thing was taken to bits and reconditioned. Thought that might have been the problem too but .......
