Are you checking this at the rad cap? You keep saying expansion tank cap, the level in there has nothing to do the coolant level.
The thermostat was not changed with the radiator. But the temp gauge in the dash goes up and down just as you would expect.
Edit - did some searching and it looks like I need to let the engine cool down properly overnight and then look inside the rad cap to ensure the radiator is full. Am I right in thinking the radiator cap seal can blow and let coolant escape? Would this cause no hot air in blowers, as well as engine overheading on revs only?
thanks
