Hi - another strange noise from front hub area, like a tyre edge rubbing on something, but it's not that. It quietens down at higher speed and I'm suspicious that it's front wheel bearing(s). There is some play in the bearing but not massive. Can anybody advise what level of difficulty I'm likely to find in replacing these bearings? The repair manual rarely covers the fu**face irritations that emerge when trying to dismantle drive and suspension bits in the surf. Any special tools needed? Does the brake caliper really need to come off? Can the outer bearing not just be accessed by removing the bearing cap and unscrewing the bearing nut? Does the whole hub need to be separated from the drive to get the inner bearing changed? And the manual describes all that stuff as 'minor maintainence' (eh??). At least the bearing kit is pretty inexpensive.
Any advice appreciated before I lie in the gutter again
....Keith
....Keith
