Hi all,
Just noticed my 3 drive belts on my '96 SSRX, KZN185 (2 x fan and an Air con belt i believe) are loose and looking a bit on the ragged side and will probably need changing out.
Is it an easy job to change 'em out?
I know my way around a socket set, but i'm not the most knowledgable around engines..are there any special tools needed or can i do the job with 'normal' tools?
Any tricks of the trade would be appreciated too!
Thinking about it, my Air con hasn't pumped out any cold air since i bought my Surf (a year ago), so wondering if i can get away with just leaving the belt off for the Air con?
Guessing that it uses extra fuel to drive the pulley, so would it be economical fuelwise to just leave it off if i'm not using it?
Cheers guys.
Cheers guys.
