Me and the wicked witch had a couple of days out this week,Anglesey on Monday and then Whitby yesterday,the weather was glorious for both days so we had the air con on.Switched it on this morning and theres a loud squeeking noise,seems to be from the pulley area of the pump,air con is working o.k.,noise starts( can only really describe it as a loud clicking or ticking )as soon as the air con is switched on,noise goes away as soon as you switch it off.pulley belt is a slightly loose but not too much,I know the clutch mechanism works magnetically and wondered if it was possible to strip it down,remove a shim and see if that cures it.
Any ideas gratefully received. Ta
