Hi guys,
Trying to find a definite answer as the search didn't come up trumps.
My rad has a slight water leak (evidence is rust patches on the inside of the matrix and brown water when running with no coolant).
I didn't know about this when I bought the car and ended up roasting the engine when the water ran out. Since then it bellows blue smoke, mostly when cold but sometimes i have seen it when idling at full temp. Seems more like the rings to me rather than the stem seals as it burns oil when its been running a while.
However could it be leaking to the cylinders if the head is cracked?
I don't have any mayo on the filler cap and the rad is not pressurised when cold so that is something.
Thanks in advance for your help.
