hi ya all, I made a terrible mistake. while replacing the battery, I exchanged the battery terminals accidentally and now the whole car acts like no battery is attached (no clock, no stereo, no lights when the key is on 'ON'). the headlights, the beeping sound, hazard lights, and the red lights on the doors work, but nothing else works. what did go wrong? fuse? please help?
please help, i think i messed up the electricals???
do I need to remove the whole fuse box first or will the two fuses (80 and 100) only slide up? if so, how do I slide it out? (sorry I have never dealt with this part before)
p.s: as I have noticed now, there is a 100amp fuse on the place of the 80amp one. will this cause any side effects, though it never did?'94 Surf SSR-X --3.0l Turbo-KZN130W -- 400,000KMs
Originally posted by tamrat View Postdo I need to remove the whole fuse box first or will the two fuses (80 and 100) only slide up? if so, how do I slide it out? (sorry I have never dealt with this part before)
Yes, change it. Never put a fuse of a higher rating in anything.Do you know that, with a 50 character limit, it's
waking up this thread again, i needed to ask one more question.
After replacing the 100amp fuse everything is back to normal but i didnt notice the radio wasn't working even after replacing the 100amp fuse. By then i just thought it was a problem of the 7.5amp fuse in the cabin. But now after checking the fuse, i can c it is fine (also the power antena works). What should i check, the radio doesn't seem tn have a fuse on it (its an old Kenwood DPX90)?'94 Surf SSR-X --3.0l Turbo-KZN130W -- 400,000KMs
