hi, I filled my surf with petrol recently and since we drained it and got it going with diesel again the brake warning light has been on, i have covered 200miles since to give the engine a good run and the batteries a good charge. I was looking to investigate the warning light issue this bank holiday but have just piked my girlfriend up to find the brake pedal is now hitting the floor and im only just about stoping eventually
. i havenent checked anything yet to be fair as i have just go in from work and im shatered. I assume i will have to take the wheel off to check the pads ?, Is there a usual problem that its likely to be ? when i was waiting for the misses to come out from work i tried pumping the brakes, the pedal did pump and nearly go hard but then a harder pump and pedal hit floor if that makes any sence. I dont really wan2 book it in garage if i can sort it myself so any advice welcome thanks.
