after using my petrol car for months on end i went and filled my 2nd gen surf with petrol. only just figured this out when i took off the filter and realised that is why she had cut out on me. it was nearly empty when i filled it and so the result is a full tank of unleaded. I will be emptying it tomorrow evening and changing the filter. any body have any advice or tips that would help ? also any body think anything will be damaged as it cut out at 80mph on the m-way. stupid mistake i know but hope its only going to have cost me the tank of fuel and new filter. where can i dispose of the slightly cut petrol as i dont think its wise to put it in the car ? thanks guys.
filled my diesel with petrol
Few mechanics - one from Toyota told me some people fill the tank 1/2 with petrol to clean the system from diesel residuals, that benefit injector system pipes and tank
..perhaps 100% petrol cause some damages only if you use it for long, I am not sure
Why bother?Originally posted by freewheel View PostFew mechanics - one from Toyota told me some people fill the tank 1/2 with petrol to clean the system from diesel residuals, that benefit injector system pipes and tank
The op needs to drain the tank then put some diesel in loosen some of the injector pipes off and crank it over without waiting for the glow plug sequence ,do this a couple of times then tighten the injector pipes then try to start.
May be a bit lumpy but will clear.
Then he should change the fuel filter.
This has been covered in more detail on the forum.
I very much doubt my surf would run on 50/50 petrol diesel.Eat.Sleep.Surf.Repeat.
