See post #44.
Sudden increase of fuel consumption
yes perhaps is wise to test the ECU, so far everyone disagreed and also toyota.Originally posted by BUSHWHACKER View PostSee post #44.
reason is because the orange engine check light do not stay on. so would not show up on ECU faults, only few sensors would not show and, I bet the turbo sensor is not one of them. (timing sensor on the denso pump could not give fault code)
anyway I found one who may properly test it, in Bury
BTW anyone know a place near manchester to test the surf engine kzn130 3.0 td ?
An ECU can in fact give no fault codes if part of the KAM (Keep alive memory) circuit is damaged it's not common but it can happen. Best to have yours checked and then if it's OK that is ruled out, so it will then be down to checking everything associated with engine control.I'M ALWAYS IN THE SH'T, IT'S ONLY THE DEPTH THAT VARIES!!!!!!!!
When did it start using more fuel?
Have you allowed for the increased fuel costs?
Are your tyres inflated to correct pressure?
How many gear shifts?
Overdrive working?
Have you done the diagnostics test yet? (Don't say, "But the check light isn't on" do the test anyway!)
Have you fitted bigger tyres or any other bolt-on accessories recently?
Have you moved house and now drive everywhere uphill?
Are your brakes dragging?
Have you started wearing heavy shoes recently?
Exactly how long is a piece of string?
Overdrive working?
Jeez I quoted alll this from the beginning of the thread,Originally posted by BUSHWHACKER View PostWhen did it start using more fuel?
Overdrive working?
New wheels kumo nfinity 16/265 with 2000 km spot on!! spent just 400 I' d sell it do you want em with the 5 damn alloy!
never added any gears and they go up to the end sweetly + OV ..but here I drive at 30
new brakes stop the car instantly like u can't even dream of.
am from the hills and never moved, wear timberland boots, as usual.
BTW I thank you for the hints, also Tony, just seems unreal.. I go by the liter and that's 6 km per liter instead than 11
I swear the car dont smokke what else can I say you take it and have a loookLast edited by freewheel; 16 May 2012, 16:03.
Originally posted by freewheel View PostJeez I quoted alll this from the beginning of the thread,
Do you work in an office?
Get it down here and I will, but will probably cost you to much in fuel...Originally posted by freewheel View PostBTW I thank you for the hints, also Tony, just seems unreal.. I go by the liter and that's 6 km per liter instead than 11
IN ANSWER TO HOW LONG IS PIECE OF STRING?
AS LONG AS YOU CUT IT!!!
The consumption is back to normal after a little offroad, thanks god.
Maybe that's what they are made for... but I suspect can be the EGR valve not making the exhaust gas to be recycled properly into the intake.
Anyone came across similar issues having to replace or clean the EGR?
It's not the EGR valve.Originally posted by freewheel View PostThe consumption is back to normal after a little offroad, thanks god.
Anyone came across similar issues having to replace or clean the EGR?Do you know that, with a 50 character limit, it's
