Hi - last MOT brought an advisory that the sump was corroded and required attention. Of course, I ignored that as there was no oil presenting at the time, but it's now leaving a pool under the truck and needs repaired/replaced. Couple of questions - I'm presuming the sump pan is a simple mild steel pressing and can be welded/plated over the corroded section?
Is it a simple matter of just taking out all the bolts that attach the sump to the block and dropping it (after draining oil)? No other seals involved round front and rear crank bearings etc?
Anyone got a spare 3.0 litre sump for sale?
cheers...keith
cheers...keith
