Hi all, i need a bit of advice from fellow kzn 3.0 td owners.
had an oil leak for the banjo bolt of the turbo oil pipe ..so bought new pipe, took off manifold, and water pipes, turbo and turbo elbow.
replaced pipe for shiney new item ..and refitted turbo (note turbo shaft had some play in it but not much)
gaskets all fine.. all fitted up and painted.
was running ok before i did this .. a wee bit of blue ish smoke on starting when really cold.. but now .. its refusing to idle.. will only idle badly if i urn her over on full throttle and shes kicking out pulses of back smoke for the exhaust ...
I did suspect the turbo may be worn, but seems odd to just suddenly go from fine to knackered... so ..anyone any idea?
as far as i know all pipes a re back inthe right place, all breathers reconnected.. only two electtical connection i moved are at the back of the hard pipe...
so, why wont she run ?
Si
