As the title says, this is about the best way that I can describe the problem accurately with my very limited mechanical knowledge.
Here's the symptoms,
When accelerating in 3rd (she's manual btw) after about 2 thousand revs it feels like she's running out of puff, there is a significant drop in power a shudder/jolt type effect, if I change up to 4th it'll stop but as soon as I get to 2 thousand revs again the same thing happens, same again when i get into 5th.
My limited brain/knowledge is telling me that it could be a turbo problem, reason being is that it happens around the 2 thousand revs mark, but i wanted to check with you guys because I know from past experience on here that there isn't anything you guys don't know.
Any ideas of what I could/should be looking at would be much appreciated.
Thanx.
Thanx.
