hi
just changed my antifreeze.
but after reading a thread on here were it said the 3L.TD kzn130 takes between 9 and 10 litres i bought 5 litres for a 50/50 mix.
flushed the system through but with the hosepipe in the top rad hose water was only coming out of the bottom rad hose very slow but i put this down to the little hole in the thermostat limited flow. flushed engine and rad until clear water was coming out them both. about 15mins in all....
connected everything back up filled with with antifreeze but it was full with about 4 1/2 litres so i put rest in expansion bottle.
i was going to top up with water but couldnt...
so now it is probaly about a 90% antifreeze 10% water mix....
should this be ok?????i was told by an AA fella years ago that they use pure antifreeze in all there vehicles at winter
